Adding Sockets to a Fixed Position Desk Unit
Knightfury
by Knightfury » Tue Jul 07, 2015 2:03 pm
Just wanted to walk through the checks on this and make sure there's no obvious flags thrown about issues.
Will be building a desk unit to go along a full wall. The desk will be free standing but definitely static once it's all set.
I'm after having a cabinet sat on the desk (doweled and screwed to the desk surface so it's not moving either). To each side and front of a section of this cabinet I wanted to mount 3 pairs of "wall sockets". These would use back-box intended for plasterboard with tweaks needed to get them sat snuggly in the cabinet. They'll sit about 6 inches above the desk.
What I'm after doing (which is the bit I doubt would pass muster) is running cable from the back of these boxes to 3 plugs. These would plug into a switched surge protected 3 way socket, plugged into a wall socket (ring main) with RCD.
I'd be pretty shocked if this passes regs but from a safety point of view, is there much needs changing?
The 3 plugs to the back of the boxes would be well secured so there's no chance of pulling. The cable would have some slack secured so there'd just be 3 clean cables to the surge protector and the RCD socket would be well behind the desks out of the way of issue.
Re: Adding Sockets to a Fixed Position Desk Unit
by ericmark » Wed Jul 08, 2015 7:12 am
It is in essence an extension lead so no real problem.
It is currently Mon Jan 13, 2025 2:38 pm
