Probably a stupid question but I am unsure whether it's possible/advisable to fix a relatively heavy (for its size) coat rack to an original tongue and groove panelled wall using No More Nails or a stronger equivalent? The coat rack is the type with a vertical panel and pegs to hang coats on, as well as a shelf above to place children's shoes or something similar - approx 70-80cm wide made of pinewood. The wooden tongue and groove wall is painted with emulsion and so quite thin (only a few mm) as there is no backing on the other side - only the neighbour's hallway!
Many thanks,
Charlie
