Bathroom sink overflow causing leak underneath when plug in
mrobbo
by mrobbo » Fri Jul 10, 2015 9:27 pm
Hi all :)
I have an issue with the bathroom sink.
When the tap is running with sink unplugged - no issue.
When the tap is running with the plug in, and therefore the water escapes through the overflow, the very bottom of the sink casting gets wetter and wetter, then forms a rapid drip.
What is causing this to happen please? I'm just wondering if it's time for a new sink or if it's fixable - a blockage somewhere maybe?
You can probably tell I'm not a plumber :)
Thanks.
Mad110
Re: Bathroom sink overflow causing leak underneath when plug in
by Mad110 » Wed Jul 22, 2015 9:45 pm
There may be a casting hole not sealed up or the basin waste may need removing and refitting with a bit of plumbers mate putty on the gasket before tightening.
It is currently Mon Nov 25, 2024 3:49 am
