What Sized Joists for 9x13 Shed Floor Framing?
Questions answered and a range of solutions on problems and issues encountered with timber framed buildings
Diyer321
by Diyer321 » Sun Jul 19, 2015 8:01 pm
Hello i am going to be building a 9x13 shed on concrete blocks and would like some advice on what size joists to use.
I want to have 6 piers, 1 in each corner and 1 on each side in the middle of the 4m length.
I havent decided how far apart to space the joists or how to attach them but i am trying to keep the costs as low as possible (while only having 6 piers) and i will cover the floor with 18mm osb3.
I think the span between piers will be about 8ft and 6ft.
I already have some 3x2's and 4x2's for the walls, cladding and fibre cement roof sheets.
Thanks in advance
Diyer321
Re: What Sized Joists for 9x13 Shed Floor Framing?
by Diyer321 » Sun Jul 19, 2015 9:46 pm
I should of mentioned i plan to hav the joists running the 9ft length of the shed and im going to make the concrete blocks myself so they will be 60cm square and 6 inch thick.
It is currently Sun Dec 22, 2024 5:28 pm
