Looking for Small Efficient Lawnmower - Ideas Welcome
Paul10
by Paul10 » Tue Jul 21, 2015 9:40 pm
Hi , am looking for a small and fuel efficient lawnmower. Any of your suggestions will be most welcome.
Thxs in adv.
DIYDoctor2
Re: Looking for Small Efficient Lawnmower - Ideas Welcome
by DIYDoctor2 » Mon Sep 07, 2015 10:49 am
It really depends on the amount of grass you need to mow. If you only have a small amount to do then maybe you would be best off with an electric mower, such as this one here: https://www.diydoctor.org.uk/DIY-superst ... -volt.html
If you have a fair size lawn that involves quite a bit of mowing then you would certainly be better off with a petrol mower (cuts better and also no wires to worry about). In terms of efficiency, most small engine petrol mowers are much of a muchness. In general, the more horsepower they have the more fuel they will use (depending on how hard you rev them and how much work they have to do), but on the flip side of this the smaller the engine and less horsepower it has, the harder you will have to rev them to do the work so the more fuel they will use, if you see what I mean.
In terms of quality and reliability - In general, the Honda mowers tend to be some of the best and most reliable.
Hope this helps
It is currently Thu Nov 21, 2024 10:16 pm
