Light Problem After Connecting new Spot Lights Lost Lights Upstairs?
Derek6647
by Derek6647 » Fri Jul 24, 2015 11:46 pm
I was wondering if you could help me.
I removed my kitchen light and decided to put in some small GU10 spot lights.
When I took the old light apart I noticed the Earth and neutral were in the same connector and the live was separate.
I ran cable to five spot lights to the left and 5 to the right. I connected the live , neutral and each separately using a connector block with the 3 live cables in one block 3 neutral cables in another and the 3 Earth cables together.
I have now noticed I have lost lighting to the upstairs rooms in my house.
Should I have joined both ends to make a loop or should I have re connected the cables putting the Neutral and Earth together.
Any assistance would be much appreciated.
Re: Light Problem After Connecting new Spot Lights Lost Lights Upstairs?
by ericmark » Sat Jul 25, 2015 5:18 pm
In the main UK system has two lines (permanent and switched) a neutral and an earth going to each ceiling rose.
When removing the rose normally a junction box replaces the rose and this allows just a switched line, neutral and earth to be fed to the lights.
Also often the switched line is a neutral coloured wire with a sleeve to show it's line, but this sleeve can fall off, and it is a common problem with DIY where the person gets the switched line and neutrals mixed up.
It is currently Mon Jan 13, 2025 9:28 am
