What Joints Need Sealing for Shower Enclosure
teecee90
by teecee90 » Tue Jul 28, 2015 7:08 pm
Can anyone please clarify something for me....
I'm refurbing our en-suite including fitting a new shower. The instructions that come with the enclosure say to seal the outside only. Fine.... I understand the reason for that and it seems perfectly reasonable. What I'm not clear about is exactly what joints I should seal!
I guess the enclosure is fairly standard - it uses a U shaped profile screwed to the wall and then the enclosure panels slot into the channel of the of the wall U profile and are then drilled and screwed to the wall profile. That means that I have two outside joints .... a joint between the wall profile piece and the tiled wall, and a joint between the enclosure panels and the wall profile.
I assume that it is the joint between the wall profile and the tiled wall that I need to seal with silicone but do I also need to seal the joint between the enclosure panel and the wall profile or is the friction fit enough to prevent any leaks?
It is currently Sun Jan 12, 2025 2:05 am
