Boiler change to Worcester Danesmoor - Wiring Diagram Advice Needed
jammersp
by jammersp » Sun Aug 09, 2015 9:26 pm
Hi all,
I currently have the following system;
1 x worcester danesmoor 15/19 boiler with internal programmable timer, a cylinder and room stat control all built into it.
There are 2 external danfoss pumps one for HW and one for CH.
I have been lucky to get a reasonably priced worcester danesmoor utility boiler, but this doesn't have a programmable controller or inputs for the room or cyclider stat, all it has is just normal mains in (presumably to just fire up the boiler).
Now the instructions say to have a pre-wired remote 10 way junction box, which then feeds the boiler with the live/neutral/earth.
I can get a 2 channel programmable controller but how will the room and cylinder stat and then the 2 pumps be accommodated, is there a specific controller that can do all of this?
One assumption of mine is to have the pumps activated with the input from the cylinder or room stat returns.
I have attached the diagram for the remote wiring - it may be useful for someone.
Any help with the wiring would be appreciated.
James
It is currently Fri Nov 15, 2024 12:47 pm
