new home office advice
urbantus
by urbantus » Wed Aug 08, 2007 5:36 pm
Im building a shed 4.8 m x 3.6 m in area with a single pitch roof front to back
Im building it on top of a concrete slab
Is it a good idea to raise the joists off the slab
Im thinking of using joists rested on three rows of 100mm thick conc blocks ie span will be 1800 mm
What size joist would you go for
I m using 22 mm t&g flooring
Plus Im using insulation in floor
What type insulation and how should I fix it
The roof will be a single pitch roof spanning front to back
ie 3600 mm span
Im using 22mm t&g plus roof felt
What size timbers etc for roof
Do I need extra supports or purlings
if so where and what size
What would be the roof pitch front to back
Thx
urbantus
:lol:
It is currently Mon Dec 02, 2024 3:51 pm
