Block up Gap Left by Removed Gas Fire
Az-wow1
by Az-wow1 » Tue Aug 18, 2015 7:25 pm
Hello, We've just moved house and had to get the gas fire removed as was leaking gas. We don't want to replace it - instead block it up and get plastered over. My question is how to block this up? This is a detached house built in the early 80's. There is a flue which goes up inside the cavity wall - in the loft it appears to be aluminium tubing, then to a chimney on the roof.
Do I just block it up with bricks/mortar or is an air brick required?
Thanks Peter
Re: Block up Gap Left by Removed Gas Fire
by welsh brickie » Sun Aug 23, 2015 3:56 pm
its best to leave 1 brick out to ventilate the flue. A plastic hit and miss vent can be installed after its plastered
It is currently Sat Jan 04, 2025 8:44 am
