How to Best Protect Knotty Pine Doors
7 posts   •   Page 1 of 1
Raul_breganzo
by Raul_breganzo » Tue Aug 25, 2015 11:46 am
Purchased a couple of knotty pine doors from B&Q. I know it's not the best of wood but it sure looks great!
How can I protect it as there are some reviews which are concerning?
Also, there are 2 knots which lets some light through. What should I do with those? I'm yet to varnish...
Btw once you varnish doors with a quality product there's no need to sand it down softly and re-varnish is there?
Thanks in advance, Raul
Raul_breganzo
Re: How to Best Protect Knotty Pine Doors
by Raul_breganzo » Tue Aug 25, 2015 9:27 pm
Any advice please!?
thedoctor
by thedoctor » Thu Sep 03, 2015 6:38 pm
Apologies for the lack of response on this - Starting with the knots, these can be filled using a Neutral Wood Filler, such as this one here: https://www.diydoctor.org.uk/DIY-superst ... 125ml.html. Once cured, sand down lightly so that it is smooth and flat.
In terms of the varnish, yes, to get the best and most long lasting finish the best approach to take is apply first coat of varnish and let it dry. Sand it down very lightly and then apply a second coat.
The best varnish to use is a polyurethane clear satin varnish such as this one here as this flexes with changing temperatures etc.... and also resists knocks etc....: https://www.diydoctor.org.uk/DIY-superst ... litre.html
Raul_breganzo
by Raul_breganzo » Mon Sep 07, 2015 5:02 pm
Great piece of advice! Thank you 'thedoctor'.
You actually sell products from this website? I shall look around for the best price and maybe order :-)
thedoctor
by thedoctor » Mon Sep 07, 2015 9:15 pm
No problems at all, good luch with the projects
Yes we do indeed, in our toolstore here: https://www.diydoctor.org.uk/DIY-superstore/
Please feel free to have a look around
Kind Regards
Raul_breganzo
by Raul_breganzo » Mon Oct 26, 2015 9:44 am
Hi again,
Can you recommend a sealant for knots please?
thedoctor
by thedoctor » Mon Oct 26, 2015 5:00 pm
Most good quality knotting solutions will do the job, obviously be aware of coloured ones depending on what colour finish you are going to use. There is a selection here: https://www.diydoctor.org.uk/DIY-superst ... tting.html
Hope this helps!
It is currently Fri Jun 28, 2024 11:21 am
