Advice Needed on Re-Tanking Living Room in Basement Flat
delv86
by delv86 » Tue Aug 25, 2015 3:20 pm
Looking for advice on re-tanking a living room in a basement flat.
How far should I take the plaster back above/underneath the existing tanking line?
Will it be necessary to take the plaster off along the tanking line for the whole circumference of the room or only the areas affected?
Any other advice welcomed.
collectors
Re: Advice Needed on Re-Tanking Living Room in Basement Flat
by collectors » Fri Aug 28, 2015 10:21 am
Hi, in a normal house the wall is usually tanked to about a meter high as water cant rise above 6/700 mm above ground level in most cases due to gravity. But a basement flat. Will be a different as your already below ground.
In a basement situation firms usually lay a concreate floor with a drain in the low point & let any water in behind a special wall membrane that looks like an egg box that comes in rolls about 25met long. So you end up with a small void in the walls & floor & diverting the water to the drain which either goes away with gravity or may have a pump with a float switch to pump the water away.
A basement is defiantly a specialist area & would recommend a qualified firm as it’s a question that will be asked when selling a basement flat & will need certification & guarantees., .
Mark Davison
by Mark Davison » Wed Oct 21, 2015 3:12 pm
^^^ 'collectors' is correct, you would need a cavity drain membrane system with drainage i.e. sump pump.
It is currently Sat Nov 23, 2024 9:13 am
