Lost Fittings for Loose Top Hole Toilet Seat - Help Needed
shonaritchie
by shonaritchie » Thu Sep 03, 2015 9:52 pm
I had a new bathroom suite fitted last year, but the toilet seat, appears to me anyway, has never fitted, and has constantly been up (fine if it's an all male household)
However, on the right hand side, there is a screw not attached to anything, and I'm not really sure about the left hand side, but it is loosely attached. I've heard rumours that I might need a new toilet, please help x
thedoctor
Re: Lost Fittings for Loose Top Hole Toilet Seat - Help Needed
by thedoctor » Mon Sep 07, 2015 12:31 pm
Its about a million-to-one that you need a new toilet Shona but probably a new seat is required. Look under the back of the pan where the old seat should be secured by either wing nuts or plastic nuts, unscrew them and lift of the old seat. Most new seats come with fitting instructions so you should not have a problem fitting your chosen seat.
KyleRonnie
by KyleRonnie » Tue Dec 08, 2015 6:58 am
Replacing whole toilet is the only solution as we had a customer on Monday almost having the same kind of problem, replacing whole toilet seat so just order good quality seat with same fixings..... good back up though..
It is currently Sun Jan 12, 2025 12:41 am
