Help Needed in Identifying LED Light Bulb
Buzzy
by Buzzy » Sat Sep 12, 2015 2:55 pm
Please help to identify this type of a LED light bulb that I removed from my new desk lamp,
as want to change it to a similar one but with a warmer light. This one is very white cold
Spent an hour on Ebay and still can't figure it out! Thanks..
Re: Help Needed in Identifying LED Light Bulb
by ericmark » Sun Sep 13, 2015 11:33 pm
That's not a light bulb it's part of a light bulb. Some LED lamps today don't have a bulb as such. The LED is part of the device and if and when they blow you swap complete device. LED's do get hot so to remove that heat they are often mounted on some material to remove the heat. Making the LED part of the device rather than a renewable part in the device helps in removing heat.
It is currently Mon Jan 13, 2025 9:08 am
