Garbage Disposal Distance from Sink to outlet Pipe Above 14cm?
Tobias Claren
by Tobias Claren » Wed Sep 16, 2015 8:43 pm
Hallo.
Is it usual, that the distance between Top Edge (or more exact under the sink) and the middle of the outlet pipe is more than 14cm?
I have a double sink. A big and a small one.
See the attached picture.
There is a space saving drain system with a bridge between the sinks.
I want to install the device under the small sink.
I need a fall from the small sink to the bigger main sink.
The Pipe to the trap at the main sink is ~14cm lower than the undersite of the small sink.
If the Distance at the Disposal has more than ~14cm, there is a rise to the main sink.
Thanks.
Double sink with space saving drain system.<br />With Brigde between both sinks.
It is currently Sun Jan 12, 2025 2:06 am
