Turning external lights on makes right light flicker
checkmate
by checkmate » Sat Sep 19, 2015 10:03 am
Hi Guys
I have recently installed the below lights to my extension
http://www.diy.com/departments/lights-o ... 911_BQ.prd
I changed the bulbs to
http://www.ledhut.co.uk/new-5-watt-gu10 ... angle.html
But what issue i have is when i turn light on the right light flickers. When i switch off and switch back on, the left now flickers and rotates, left to right!!!
What could the issue be? is it the bulb ive changed it to?
Re: Turning external lights on makes right light flicker
by ericmark » Sun Sep 20, 2015 6:46 am
The lamps are dimmable so will look for signals from a dimmer. I will guess some item is putting a signal on the power which is being seen by the lights as a command to dim. There are some silly devices which use the mains to transfer LAN signals around the house which it seems also upsets other devices reading the AC mains for signals.
If you used cheap non dimmable lamps likely there would be no problem.
It is currently Fri Nov 22, 2024 11:28 pm
