Sanding and Oiling B&Q Beech Solid Wood Worktop Query
JWMP
by JWMP » Sat Sep 19, 2015 4:19 pm
I recently purchased a worktop (Cooke & Lewis Beech Solid Wood Square Edge Kitchen Worktop from B&Q). My question is regarding both sanding and oiling. The instructions state: 'start with 100, 150, 220, finishing off with 600 grit sandpaper'. I've purchased one sheet of each, hoping that this is enough for the 3m by 600mm by 27mm surface area? Although it mentions oiling, the instructions aren't at all clear as to when I should oil the worktop. Would I sand with the 100, then 150, then 220, then 600, then oil the worktop with Danish oil 3 or 4 times, or oil between sanding, or oil in tandem with using the final 600 grit sandpaper. I've read online that when 600 grit is used you can't then re-oil?
Also, with regards to cleaning the worktop of dust prior to oiling, is it okay to use a damp cloth?
Any advice would be gratefully received.
thedoctor
Re: Sanding and Oiling B&Q Beech Solid Wood Worktop Query
by thedoctor » Wed Sep 30, 2015 1:07 pm
I think you will probably need at least a few sheets of each as sandpaper wears the more you use it so you want to ensure an even level of sanding as you complete each stage.
In terms of the oiling, you would normally do the prep work e.g. sanding and then apply the oil. We have a project on living wooden worktops here that may be of some help: https://www.diydoctor.org.uk/projects/treatwtops.htm
Kind Regards
It is currently Fri Jan 10, 2025 3:28 pm
