Thicker kingspan or insulated plasterboard in 1907 granite stone house
johnjross
by johnjross » Mon Sep 28, 2015 1:24 am
Im hoping someone can help. I have a 1907 granite stone house. I have removed all of the old lath and plaster and am looking to insulate everything. For my external walls I was considering framing the walls with 3x2 posts, then insulating with 75mm of kingspan and plaster boarding ontop. I have just been looking at insulated plasterboard and reading about thermal bridging. Would I be better to make my frame of 2x2 posts with 50mm kingspan and 25mm insulated plasterboard ontop?
Any advice is much appreciated.
John
Re: Thicker kingspan or insulated plasterboard in 1907 granite stone house
by welsh brickie » Tue Sep 29, 2015 10:28 pm
use 2x2 treated timber to frame the walls, insulate with 50mm kingspan , vapour barrier then stapled to the timber, then screw 12.5mm plasterboard
johnjross
by johnjross » Wed Sep 30, 2015 9:08 pm
Thank you, should I simply use 12.5 standard plasterboard or go extra and add insulated plasterboard if my insulation is only 50mm? On the assumption that more is always better?
It is currently Mon Dec 23, 2024 6:46 am
