Toilet leaking from where cistrrn sits on pan when flushed
loga
by loga » Mon Sep 28, 2015 1:29 pm
Hello
Apologies if this is a very simple/quick fix problem.
Whenever I flush my toilet, water leaks from where the cistern sits on top of the basin. Please can anyone advise on what could be the cause?
Any advice would be much appreciated.
Thanks.
rap12
Re: Toilet leaking from where cistrrn sits on pan when flushed
by rap12 » Sat Oct 24, 2015 3:52 pm
Usually its the "do-nut" ring between the cistern and the pan. On some close couples its the cistern fixing bolts.
ither way the only thing to do is to "break" the two parts of the WC and clean and replace do-nut (with a rubber one) and equally tighten bolts.
SOS Plumbing
by SOS Plumbing » Sun Oct 25, 2015 9:40 pm
I would first ask you to view the short video.
https://www.youtube.com/watch?v=7ClsMiln7Fs
Hope this helps you.
It is currently Fri Nov 22, 2024 6:05 am
