What to do with Plaster on Bedroom Walls after Stripping old Paper
potash1984
by potash1984 » Thu Oct 08, 2015 11:59 am
I have stripped the wallpaper off the bedroom walls so I can paper it. However, there is plaster on the board walls and I've removed the loose plaster as it was crumbling and falling down. I dont know whether to just paper over it with plaster on 90% of the walls or to remove all the plaster which will take me a lot of effort and time. Please can you help
diydoctor6
Re: What to do with Plaster on Bedroom Walls after Stripping old Paper
by diydoctor6 » Tue Dec 22, 2015 12:17 pm
Hi potash1984,
It all depends......!
You might be able to get a way with using something like Fill & Skim to patch up the holes, if they are not too big. If they are then you might have to tear it all down and start a fresh.
Have a look at our video on using Fill and Skim on patching a ceiling:
https://www.youtube.com/watch?v=fFuGNqjskGo
You can order some here: https://www.diydoctor.org.uk/DIY-superst ... e-tub.html
It is currently Sat Nov 23, 2024 7:39 pm
