Struggling with Working out Volume to Extend Concrete base
seaneylad
by seaneylad » Mon Oct 12, 2015 2:43 pm
Went online calculator and states i need just shy of 1tonne of dry mix in 25kg bags from the likes of wickes/b&q surely cant be right.
Im extending a concrete base. roughly a little 2x2m with 100mm (10cm) depth as shown,
Lost on how much all in one dry mix i should get to complete the job with a mixer?
anyone able to help / point me in the right direction ? online calcuators dont look/sound right? :S
diydoctor6
Re: Struggling with Working out Volume to Extend Concrete base
by diydoctor6 » Tue Dec 22, 2015 11:04 am
I guess you have tried our concrete calculator:
https://www.diydoctor.org.uk/projects/mi ... ncrete.htm
Using your measurement you will need the following amounts (C20 Mix):
Cement: 256 kgs
Sharp Sand: 480 kgs
Gravel: 960 kgs
Water (litres): 141 ltrs
Here is more information on building a concrete shed base:
https://www.diydoctor.org.uk/projects/shedbase.htm
It is currently Wed Nov 27, 2024 10:01 am
