Hairline Cracks have Appeared in Newly Skimmed Wall - How to Fill These
6 posts   •   Page 1 of 1
Raul_breganzo
by Raul_breganzo » Wed Oct 21, 2015 10:30 am
I have several hairline cracks on my newly skimmed (3 months old) walls and ceilings. What's the BEST way to seal them filler or caulk? Should I make the crack wider with a knife so the substance moulds in well????
Please advise and ASAP! Thanks in advance.
Regards, Raul
Re: Hairline Cracks have Appeared in Newly Skimmed Wall - How to Fill These
by welsh brickie » Wed Oct 21, 2015 10:22 pm
use caulk to fill the cracks
Raul_breganzo
by Raul_breganzo » Mon Oct 26, 2015 9:47 am
Any reasoning behind this please - mixed reviews everywhere!? Also, what about acrylic paint - does that help???
thedoctor
by thedoctor » Wed Oct 28, 2015 5:43 pm
If you use caulk then this will be remain flexible and allow flexibility with the general movement of the house. Your house will move constantly, with different materials moving, expanding and contracting at differing rates depending on temperature, humidity etc…
It is likely that the cracks have appeared due to this.
By using caulk this will allow some movement and should hopefully prevent the cracks from appearing due to the same reasons in the future.
If you are painting the surface then you will also need to purchase a caulk that can be painted
Hope this helps
Raul_breganzo
by Raul_breganzo » Mon Nov 09, 2015 2:08 pm
Thanks, didn't see your response until now!
Yes, I have bought caulk which can be painted on. I have also bought this product as I've got a few hairline cracks (extremely faint) in different directions on my walls! I thought this product would help...?
(http://www.homebase.co.uk/en/homebaseuk ... 0ml-691259)
thedoctor
by thedoctor » Mon Nov 09, 2015 5:45 pm
Unfortunately I haven’t used that product before so cannot say 100% if it will do the job but from the description it looks as if it should.
The key is really as long as it is flexible and will move with any further movement of materials etc…. so that the cracks do not appear again
Kind Regards
It is currently Sat Nov 23, 2024 7:20 pm
