Tips and Advice Needed on How to Replace a Bathroom Mixer Tap
KennyG
by KennyG » Wed Oct 21, 2015 2:59 pm
Need to replace a mixer bathroom tap but looking at a couple of Youtube videos on the subject it looks far more complicated than replacing a single hot or cold tap. Is this something which could be done by a novice or should I bite the bullet and pay for a plumber? Annoyingly, most of the existing tap seems OK but the horizontal lever which turns the water on & off won't stay in properly when it's screwed in, something wrong with the thread I think. Any help appreciated!
diydoctor6
Re: Tips and Advice Needed on How to Replace a Bathroom Mixer Tap
by diydoctor6 » Tue Dec 22, 2015 9:42 am
Hi KennyG,
Here's a great set of instructions for how to replace mixer taps (or mixer valves) in a bathroom:
https://www.diydoctor.org.uk/projects/mixervalves.htm
It does depend on your DIY confidence level, but replacing a mixer tap is something many DIYers can do. Good luck with it.
If you are looking for a plumber, you can find a local one here:
https://www.diydoctor.org.uk/find-tradesmen/
It is currently Tue Jan 07, 2025 1:34 am
