Fixing a Banister that has Come Away from Wall Support
Cluelessdiyer
by Cluelessdiyer » Mon Oct 26, 2015 6:46 pm
I'm a complete novice and need advice on how to fix our broken banister. It was like this when we moved in. It's come away from the support on the wall. How do I go about fixing this?
Gh1987
Re: Fixing a Banister that has Come Away from Wall Support
by Gh1987 » Tue Oct 27, 2015 6:55 pm
Skew screw it back from the underside of the handrail back to the half newel post. Can counterbore the hole then fill it in with 2 pack wood filler
diydoctor6
by diydoctor6 » Tue Dec 13, 2016 1:31 pm
Gh1987 has got it spot on.
If you want to get more information about how the handrails, banisters and newels all fit together there is a great project here:
https://www.diydoctor.org.uk/projects/ba ... drails.htm
This should give you a little more understanding about how they all fit together, so you'll be able to see how you can fix them!
It is currently Fri Jan 10, 2025 7:54 am
