What to use to Fill Grooves in Old Table Top
chriskingston
by chriskingston » Tue Oct 27, 2015 12:57 am
I'm trying to restore this old table. It's solid wood, and the top needs a good sand and oil, so the colour will probably lighten a bit once I've done that. But there are some quite deep grooves in it:
I've put a penny in it for scale.
What can I fill it with? I don't like fake wood or wood-coloured filler. I wondered about some plain black filler. Or is it best just to leave it - but the grooves are definitely big enough to be dirt traps?
What has anyone else done with similar things?
Thanks,
Chris
thedoctor
Re: What to use to Fill Grooves in Old Table Top
by thedoctor » Tue Oct 27, 2015 9:13 am
These grooves are quite typical of tables of this type, my parents have one that is very similar with the same grooves.
As they are a bit of a feature of the table it may be worth leaving them as they are a cleaning regularly to remove any dirt and grime.
If you did want to fill the gaps, it may be worth trying a neutral or dark wood filler such as those available from Liberon as this can be varnished, waxed and painted: https://www.diydoctor.org.uk/DIY-superst ... 125ml.html
Hope this helps
It is currently Fri Jan 10, 2025 11:53 am
