Adding Skylight to a Brick Built Shed Roof for Natural Light
caatah
by caatah » Tue Oct 27, 2015 8:33 am
Hi there,
We're thinking of converting one of our outside sheds into a room which we could actually use, and our first step is to get some natural light in there.
The walls are brick, so thinking it might be easier to fit a skylight window on the roof, but just don't know where to start. I'd like to read a bit about it and see if it is something we could DIY.
Can anyone let me know roughly what needs doing, and where to shop for the correct bits? Or point me in the direction of something i could watch or read. I am fairly handy, so if its not overly complicated I reckon i could do it.
Photos attached
Thanks,
Allan
thedoctor
Re: Adding Skylight to a Brick Built Shed Roof for Natural Light
by thedoctor » Tue Oct 27, 2015 9:25 am
Hi Alan
You could indeed add a roof window or velux-type window or even a roof dome, there are several options.
The key to adding anything like this is ensuring that it is obviously water tight once it’s installed. We have a few projects on installing Velux windows and also sun tunnels (that include videos) that should cover pretty much all the basics e.g. cutting the roof, adding battens etc…. of what you need to know. The projects can be found here: https://www.diydoctor.org.uk/projects/roofwindows.htm and here: https://www.diydoctor.org.uk/projects/in ... tunnel.htm
Hope this helps
caatah
by caatah » Tue Oct 27, 2015 9:45 am
Thats great, thanks for that.
I will have a look tonight!
It is currently Wed Jan 08, 2025 3:30 pm
