Hot Water Sometimes goes Cold off a Combi Boiler to Taps and Shower
kensitp
by kensitp » Sun Nov 01, 2015 8:45 pm
Hi, I have an intermittent issue where the hot water to the taps and shower from our combi boiler sometimes decides to run cold. The pressure to the taps has always been low, as it takes ages to run a bath even when the water is coming through hot. Having investigated I think the problem only occurs when the central heating is also drawing from the combi, would that explain the issue and why is this? Do I have a problem with the boiler or the water supply to the boiler?
Thanks in advance
It is currently Tue Dec 24, 2024 6:15 pm
