Problem with Heating System and Radiator not Warming up Correctly
Hazel15
by Hazel15 » Wed Nov 04, 2015 10:51 pm
I'm having problems with some of my radiators.
Some of them get red hot, but others get barely lukewarm. They're warmer at the top than the bottom so I drained it down and put some sentinel x800 in it thinking it was probably sludge.
One of the radiators that wasn't working started to get hotter but the other it wasn't making much difference for so I left it in, it's now been in a week and a half but the radiator that was starting to get hot is now not heating up again.
What could it be?
Should I give up and drain it out or leave it in longer?
thedoctor
Re: Problem with Heating System and Radiator not Warming up Correctly
by thedoctor » Thu Nov 05, 2015 8:40 am
There can be numerous reasons for this, we have quite a few projects on this subject that may help some more as they may need bleeding or it could be the TRV if your radiator has one:
https://www.diydoctor.org.uk/projects/ra ... oblems.htm
https://www.diydoctor.org.uk/projects/th ... valves.htm
https://www.diydoctor.org.uk/projects/bleedrads.htm
https://www.diydoctor.org.uk/projects/ce ... oo-hot.htm
https://www.diydoctor.org.uk/projects/drainch.htm
Hope this helps
It is currently Wed Jan 08, 2025 5:03 am
