Need Recommendation on Replacing Damaged Dual Glaze Window Pane
reysmith
by reysmith » Fri Nov 06, 2015 2:59 pm
Hi there,
1 month ago, the inside pane of my one of the ecoclassic double hard window amazingly damaged, more destroyed. Assume from the cold>heat>cold temperature. There is a factor where can see, it all began happening. The outside glass is definitely excellent.The house is 8 years old. I am asking about wether its protected in our contractors assurance to substitute it or the building insurance.
How do I go about calling someone to substitute it before we go international in 2 weeks from now. Also the price obviously if its not protected with contractors and if replacing it from own money is less costly than paying other charges to building insurer. The window is approximately 200 high and approximately 80 wide.
Much appreciate all your help.
Re: Need Recommendation on Replacing Damaged Dual Glaze Window Pane
by welsh brickie » Sun Nov 08, 2015 4:19 pm
the glass unit has failed, air has entered the space between the two panes causing condensation.
The only way is to replace the glass unit, call your local double glazing company for a quote
It is currently Fri Nov 15, 2024 8:49 am
