Laminate Beading and Cutting Curves around Stair Treads?
Jimcub
by Jimcub » Sat Nov 07, 2015 2:15 pm
I have laid laminate flooring and am ok with straight and angled bends, one thing that I find difficult is around the bottom stair tread.
Is there a way I can curve the trim to follow the tread, if not how is this done as it must happen in 100's of homes each year.
Re: Laminate Beading and Cutting Curves around Stair Treads?
by welsh brickie » Sun Nov 08, 2015 4:15 pm
cut V grooves in the back of the trim every 20mm and at half the depth of the trim it should bend enough for you to pin it in place
Jimcub
by Jimcub » Sun Nov 08, 2015 6:08 pm
Thanks I'll try that, I got the floor to fit round the stairs quite well which is a first
It is currently Fri Nov 22, 2024 6:19 pm
