Tilt and Turn Window and Handle Spinning around and Window Stuck on Tilt
Becci
by Becci » Sun Nov 15, 2015 12:28 pm
I have upvc windows which are tilt and turn.
The window in the bathroom is now stuck on tilt and the handle will not change the position as it is spinning nearly 360 when I try change it.
I have taken the handle off to see if its the handle however even with a tool I cant get the window to click back into closed or turn open, I also can't manually push the mechanism to change.
I'm unsure if its the mechanism or the handle and as its on tilt its hard to be able to work out the issue.
Any ideas are welcome. Thanks
It is currently Mon Dec 23, 2024 5:45 am
