Pattern Imprint Concrete Work Done now White Patches Appeared
markmanchester
by markmanchester » Tue Nov 17, 2015 1:55 pm
Hi all, first post, any advice appreciated :-)
Had a pattern imprint concrete job recently small garden 6 meter square.
Seems OK but has developed white patches, pic attached.
Builder says it is condensation and he will remove with xylene.
Does this seem right?
The desired colour is the reddy one seen in the central "brick" and all the other white seen is undesired.
He says cant do it until early 2016. Should I push for earlier date?
Thanks.
tileclipproman
Re: Pattern Imprint Concrete Work Done now White Patches Appeared
by tileclipproman » Sun Dec 20, 2015 4:47 pm
The concrete will take a while to cure so its probably best to wait for the builder.
neil-the-handyman
by neil-the-handyman » Tue Sep 27, 2016 12:41 am
Hi Neil the Oxford handyman here,
The white is more than likely nothing more than natural salt content leaching out. This was probably present in the quarry sand. You may notice it on numerous new builds. Don't panic it will dissolve over time and dissipate and not affect the strength of the structure.
Hope this helps,
Kind regards
It is currently Sat Nov 23, 2024 3:40 pm
