Rendering
barkcroft
Rendering
by barkcroft » Fri Aug 10, 2007 8:46 pm
Can any body tell me how thick Ican go with a sand and cement floating coat on internal walls thanks.
Ross Boseley
by Ross Boseley » Sat Aug 11, 2007 7:15 am
Hi mate,
Basically you should put it on at 11mm but if you need to go deeper then you can just keep building out to your required depth in stages of no more than 11mm.
Hope this helps
Ross
It is currently Sat Nov 23, 2024 2:19 pm
