Kao 5 Switch Connection Advice Needed for Cment Mixer
satinseat
by satinseat » Mon Nov 30, 2015 10:50 am
hi,
got a replacement kao 5 switch for a cement mixer where the wires are presently joined together as the original switch broke.
new switch has 6 terminals marked 11 21 31 on one side and 12 22 32 on the other - I was hoping for L N E markings but no such luck.
any advice please as to which is which
thanks
ian
Re: Kao 5 Switch Connection Advice Needed for Cment Mixer
by ericmark » Wed Dec 02, 2015 1:59 am
I always use my meter on the rotary on/off switch as one can never be sure with numbers I have and I am sure many others have stripped switches down and moved cams to do what I want so it's always best to test with meter rather than rely on numbers being correct.
It is currently Fri Nov 22, 2024 10:19 am
