How to Deal with and Fix a Small Area of Peeled Paint
robin telfree
by robin telfree » Wed Dec 02, 2015 1:32 pm
Hi all,
I've recently (3 months ago) painted a room and there is a small patch that has slightly peeled. I've just used a scraper to remove this small patch and the surrounding area (about 30cm x 8cm) and was planning to use some diluted paint to ensure it doesn't peel again. However, the patch I've now exposed is more indented than I had expected and I'm worried that painting alone will leave a clearly visible indentation. One option would be to use some filler but I think it is too shallow a patch, so I feel a bit stuck.
Any ideas would be much appreciated as I've made a very slight imperfection now look like a a complete eye sore! Should I just paint, should I use filler, or is there some other trick?? Many thanks in advance.
thedoctor
Re: How to Deal with and Fix a Small Area of Peeled Paint
by thedoctor » Tue Dec 22, 2015 11:28 am
Get busy on the edge of the peeled area with some samdpaper and "feather" the edge of the paint down from its original thickness to 0 where it meets the peeled area making a veryb gentle "slope" in the paint which will then be considerably less visible when over-painted
Leebasten
by Leebasten » Mon Jan 11, 2016 4:50 pm
Hi a good solution is to fill area with a ready mixed joint filler (the type dry liners use) it's easy to rub down and will fill the thinnest,apply a watered down coat of paint, let dry and paint as normal.
Hope this helps
It is currently Mon Dec 23, 2024 7:43 pm
