Question about using Radkit Pro to Remove Radiators for Wallpapering
Eileene
by Eileene » Thu Dec 17, 2015 6:51 pm
I've bought a Radkit Pro, I need to wallpaper behind 2 rads.
The instructions say to isolate the valves. Two questions!
1. which nut in the photo is the one to turn?
2. the other end has a thermostatic valve which, if I turn it off, will isolate that valve... is that correct?
Many thanks!
http://skichic.tumblr.com/post/135392997090
thedoctor
Re: Question about using Radkit Pro to Remove Radiators for Wallpapering
by thedoctor » Fri Dec 18, 2015 9:20 am
In answer to your questions:
1 - It’s neither of the 2 nuts that you have labelled in the photo. To isolate the valve, you need to turn the small protruding “stem” on to of the nut labelled 1 that has the 2 flat sides to it. This will isolate the valve and shut it off. You need to turn this clockwise
2 - In answer to this, yes that is correct
We also have a product review page of the Radkit that you may also find useful: https://www.diydoctor.org.uk/product-rev ... review.htm
Hope this helps
Eileene
by Eileene » Fri Dec 18, 2015 11:42 am
Ah right, thanks so much for that.
It was your review video I watched before buying the Radkit Pro. You made it look so easy I thought I'd give it a go; wish me luck!
Many thanks!
It is currently Tue Jan 07, 2025 12:11 am
