Advice on Building a Built-in Cupboard in Irregular Shaped Alcove
Manchester Meldrew
by Manchester Meldrew » Fri Jan 01, 2016 2:12 pm
Hi, I am new to these forums and a fairly inexperienced DIYer.
I would like to build a cupboard in my hall in an irregular alcove (measurements below). The floor is concrete and I would like it to be from floor to ceiling.
Firstly I would appreciate advice on how to make the frame and how to anchor it.
Many thanks
John
Manchester Meldrew
Re: Advice on Building a Built-in Cupboard in Irregular Shaped Alcove
by Manchester Meldrew » Sat Jan 02, 2016 3:17 pm
Improved graphic on what I want to achieve, with double doors on front.
tileclipproman
by tileclipproman » Sat Jan 02, 2016 6:50 pm
First thing you need to decide what the cupboard will be used for ie will it have shelving?is it L shaped what type of doors and so forth.
Manchester Meldrew
by Manchester Meldrew » Mon Jan 04, 2016 9:26 pm
Thanks for the reply tileclipproman.
The cupboard will be rectangular, mainly used to hang coats etc with one or maybe two shelves above for suitcases.
Given the lack of room in the hall I am considering two doors and perhaps a top hinged single door for the upper section. Ceiling height is 8ft.
It is currently Mon Jan 06, 2025 9:28 pm
