Shower seal problem cannot see how water is leaking through
Johnsonsyard
by Johnsonsyard » Sun Jan 10, 2016 11:15 am
Hi please help. At the end of my tether , sick of this -----------shower. Seven times have sealed top of bath with seal under the shower head and seven times it has failed. Cannot not see how it is getting through. Checked pipes , no dampness. What should I do now . Any advice greatly appreciated as really getting on my wick. Regards nick
tileclipproman
Re: Shower seal problem cannot see how water is leaking through
by tileclipproman » Thu Jan 21, 2016 7:02 pm
are you saying the sealant is not doing the job or there is another problem
send photo if you can,are you using the right sealant?as if you are using a water based sealant it will just wash away as soon as it gets wet.
melving.crane
by melving.crane » Mon Mar 21, 2016 6:32 am
Hey there, have you found solution of your problem?
lets have a look
by lets have a look » Wed Mar 23, 2016 9:17 am
are you sure that is what's leaking, how well are the taps sealed,I would check the overflow,direct the water on the chrome piece that the plug attach's to,take off the bath panel and check if the oveflow combination pipe is leaking
It is currently Fri Nov 22, 2024 7:17 am
