Sealant Between Wood Worktop and Glass Splashback
proftanda
by proftanda » Sat Jan 16, 2016 5:38 pm
Hi there,
I'm fitting a wooden worktop in my new (ex-display) kitchen.
The kitchen came with an mdf board that was the splashback - fronted with a plastic coating (it looks like a plain laminate worktop).
I'm using this but I'm adding a glass splashback panel to go behind the hob.
The worktop is oiled walnut (I've just applied a 4th coat of tung oil!)
Can anyone recommend what sealant I should use (if any) for the join between the worktop and the two kinds of splashback?
The splashback is coloured so I'd ideally seal in something clear/invisible or to match the wood.
Thanks!
Nick
tileclipproman
Re: Sealant Between Wood Worktop and Glass Splashback
by tileclipproman » Sun Jan 17, 2016 1:21 pm
what ever you do not use a water based silicone.
proftanda
by proftanda » Mon Jan 18, 2016 11:57 pm
Thanks. How about an oil based mastic like this?
http://www.sealantsandtoolsdirect.co.uk ... 24843.html
The largest gap I need to fill is about 2-3mm. It says I only forms a skin rather than completely drying.
Have you got any experience of this?
Thanks!
Nick
It is currently Sun Dec 22, 2024 4:28 pm
