Connect Visible Chrome Waste to Waste in Wall so That it is Neat
ConcreteFloater
by ConcreteFloater » Mon Feb 01, 2016 10:17 am
Hello,
I am trying to install a chrome waste pipe that is visible under a washbasin. It is supplied with a chromed cover/flange that will cover the connection and hole in the wall.
My question is how should I install this so that it is neat?
I was thinking to connect it to a compression fit elbow inside the wall so that the full length of the chrome pipe extends from the wall. The tiler can then work around the pipe and I can cover his work with the cover that was supplied.
My concern is the security of a compression fitting buried in the wall.
Do any of you have a better or neater solution?
Thanks in advance.
It is currently Tue Jan 07, 2025 12:15 am
