I have an existing outdoor light (with a sensor that doesn't work, but not needed) which I presume is wired with 3 core cable. I want to add a bulkhead light (60 watt bulb) further down the outside wall to light up the front gate to help with reversing the car at night.
I would like to wire up this bulkhead light by joining the cable, via a junction box, to the existing outside cable of the sensor light. Which would mean both lights coming on together from the one internal switch.
The instructions for the bulkhead light specify the use of a 2 core cable. Would it be OK to connect this cable to the Live and Neutral terminals in the junction box?
What is the correct size cable for the new light - 1.5mm, or less 0.75, say?
And, finally, is it OK to use pvc sheathed cable outdoors (only reachable by ladder) or do I have to use special outdoor cable (which the sensor light does not) ?
I would welcome some advice on this.
Chris
