Can I Create a Spur from an Isolated Socket?
barlzy
by barlzy » Sun Feb 07, 2016 3:11 pm
Hello
Is it possible to spur from an isolated socket? I have a socket right in the middle of the wall which has a switch 5 feet away for an electric fire. socket would be ideal to spur from for my TV on the wall as I could fish straight down to it. Not sure of the regs please advise. I am aware that the socket would also be isolated by the switch.
Thanks.
Re: Can I Create a Spur from an Isolated Socket?
by ericmark » Mon Feb 08, 2016 4:27 pm
We have radials, ring finals and spurs and the rules vary according to how that socket is fed.
I would expect if you swapped the switch for a switched fuse connection unit then you can likely add as many sockets as you like.
But can't be a 100% without further information. It may not need a FCU but I would say with a FCU you are safe.
by ericmark » Tue Feb 09, 2016 1:37 pm
I missed any new cable buried in the wall or new sockets need RCD protection. You can get RCD FCU but it all depends what you have to start with.
It is currently Mon Jan 13, 2025 6:21 am
