Wall and Door OPening Repair Needed After Tree Root Damage
naughtyneck
by naughtyneck » Mon Feb 15, 2016 4:42 pm
I have inherited a problem from my Father in Law who has fallen Ill. We have a room which is currently being re-done, its had a new door fitted (leads outside) but a tree decided to try and move in so there is a root growing through the wall. That's been killed off but the wall needs repairing and also where the door is fitted the wall need repairing all around the edges. Someone much better than I will do the rest but I would like to do this myself if its possible. I'm not a DIY expert but can follow instructions quite well and have successfully done a roof repair recently. The damage is obvious from the images, just looking for some guidance / pointers as to how I should best do this or if it looks like something that would be too big a job.
Worth noting that the job doesnt need to be a-mazing, but nor do I want to bodge my way through it.
Thanks!
Door / wall repair
Door / wall repair
Wall repair
Wall repair
It is currently Fri Nov 15, 2024 5:51 pm
