How do I Remove These Green Stains From Fencing?
yr20405
by yr20405 » Thu Feb 18, 2016 3:21 pm
I tried using the jet wash to remove it but it doesn't work any other ideas?
thedoctor
Re: How do I Remove These Green Stains From Fencing?
by thedoctor » Thu Feb 18, 2016 5:24 pm
If you have already tried the power washer, this is normally your first stop, If this hasn't worked, have you tried it again? Sometimes takes a few goes to really make a difference
Failing this you could also try bleach. Brush some bleach on, leave it to sit for 10 mins or so and then give it a good scrubbing (wear protective clothing, rubber gloves and eye protection when doing any of this though). Once scrubbed, wash off with clean water. This normally gets off a fair bit but in some cases not all of it.
If you have any remains left then you should then be able to sand this off but you may need to leave it to dry out thoroughly first though
Hope this helps
It is currently Wed Feb 05, 2025 10:41 am
