Do I Need Expansion Joints for Victorian Tiled Path Over Concrete Slab
robhdg
by robhdg » Thu Mar 03, 2016 11:04 am
I'm pouring a reinforced concrete slab 10metres long by 1 metre wide. I intend tiling the slab with black and white victorian mosaic tiles.
Do I cut in expansion/control joints on the slab? If I do cut expansion joints, do i tile directly over them, or fill them first?
appreciaate any advice
Re: Do I Need Expansion Joints for Victorian Tiled Path Over Concrete Slab
by welsh brickie » Fri Mar 04, 2016 7:46 am
yes its best to have expansion joints, I would use two, and tile over them
JustinMBeckett
by JustinMBeckett » Fri May 27, 2016 4:50 am
Definitely! You'd need these to avoid cracks on your concrete. No matter how properly laid the tiles may be, the base concrete slab would crack without expansion joints.
It is currently Mon Dec 23, 2024 5:44 pm
