Hack Off Old Plaster Before Boarding and Dry Lining Over it?
henrythedog
by henrythedog » Tue Mar 08, 2016 9:54 pm
We recently moved into an old two story, stone house which we're about to start renovating (room by room). First job is to plaster the bedrooms — plasterer has advised framing out the room, filing void with insulation on the two exterior walls and then board & plaster. My question is should I hack off existing plaster or just board over it? What are the pros/cons to hacking off the plaster back to the stone work?
lets have a look
Re: Hack Off Old Plaster Before Boarding and Dry Lining Over it?
by lets have a look » Sun Mar 27, 2016 8:42 am
I can't see any benefit from hacking off the old plaster, personally I would buy plasterboard with a foam backing
It is currently Fri Nov 22, 2024 10:50 am
