Replacing Conservatory Window Sill Corner Joints at 90 Degrees
Conservatories are a great all-round addition to any home. Find help, advice and information on all aspects of this area.
Kateminshull
by Kateminshull » Sat Mar 12, 2016 12:22 pm
I have recently moved into a house, but the joint cover, PVC, of a 90 corner is completely cracked and damaged.
Is there any way of replacing it without replacing the whole window sill.
Or any suggestions of how to improve it?
Many thanks in advance
thedoctor
Re: Replacing Conservatory Window Sill Corner Joints at 90 Degrees
by thedoctor » Mon Mar 14, 2016 9:10 am
It is possible to cover joints with new strips so pop down to a local Double Glazing Company (You can usually find Premiere Windows or Permaframe on a trading estate in most towns) and show them a photo of what you mean. They can then suggest the best method for fixing and supply the materials for you
Kateminshull
by Kateminshull » Mon Mar 14, 2016 10:40 am
Thank you. I will try that : )
It is currently Sun Dec 22, 2024 3:41 pm
