Very Wet Gable Wall and Water Ingress Around Top of Downstairs Window
myzopoda
by myzopoda » Mon Mar 28, 2016 8:10 pm
Our house is located so that whenever it rains the wind drives the rain directly into our south-facing gable wall. We've been having problems with water ingress around the top of the downstairs windows (another story but related) but recently i drilled some holes near the top of the wall and was surprised to find that what came out had the consistency of very wet clay. It actually sizzled on the drill bit as the water evaporated. It reminded me that when we had the boiler put in 4 years ago the fitter commented that our wall was very wet and the core he drilled out was like clay. Is this a big problem? Is there anything i can do about this? Would rendering help?
Any advice would be much appreciated!
Re: Very Wet Gable Wall and Water Ingress Around Top of Downstairs Window
by welsh brickie » Mon Mar 28, 2016 10:15 pm
I would consider a type of cladding to the gable, Rather than a render, It will protect it to some degree but either tiles or a upvc cladding, would be better, Sounds like the water has penetrated deep into the wall.
myzopoda
by myzopoda » Mon Mar 28, 2016 11:29 pm
Many thanks for your advice. I guess the tiles would allow the wall to dry out over time whereas rendering would seal in the existing moisture? Not sure it would fit in with the neighbourhood but it's better than the wall collapsing!
It is currently Fri Nov 22, 2024 11:03 pm
