Can I Switch on Economy Switch Before Midnight to Heat Water?
Tranmere_Paul
by Tranmere_Paul » Tue Mar 29, 2016 12:37 am
My GF has just an emersion tank to heat water and there is no timer. There are two thermostats, each with wiring to a switch each. The bottom of the thermostats is labelled as Economy.
Her meter is pay as you go with dual tarriff and the cheaper tarrif starts at midnight.
She has no timer and doesnt want to stay awake till after midnight to put the water to run at night. If she switches the economy switch on before midnight will it start charging straight away or will that switch be linked to the cheaper electricity feed and start heating water on midnight?
Thank you
lets have a look
Re: Can I Switch on Economy Switch Before Midnight to Heat Water?
by lets have a look » Wed Mar 30, 2016 7:57 am
leave the economy switch on,it will come on automatically at 12,but remember to switch off the other one as this works 24/7
It is currently Tue Jan 07, 2025 12:02 am
