Fitting a Flexi Pipe Connector to an Isolation Valve for Toilet Cistern
thesaltdog
by thesaltdog » Wed Apr 06, 2016 8:55 pm
I'm fitting a new toilet and want to remove the existing copper pipe for the cistern and replace with a flexi connector, there is already an isolation valve fitted but i'm not sure how to connect it to the flexi connector correctly.
This is the flexi connector I'm looking at:
I'm assuming the connection on the right (with the rubber washer) gets connected to the cistern, if that is the case how to do I connect the other end to an isolation valve? Should I use a female coupler?
Or have I got the connections the wrong way round and should fit the end with the rubber washer to the isolation valve with a male coupler?
Nick
lets have a look
Re: Fitting a Flexi Pipe Connector to an Isolation Valve for Toilet Cistern
by lets have a look » Thu Apr 07, 2016 8:25 am
you need a 1/2" by 1/2" flexi connector,not a 1/2" x 15mm flexi
https://www.google.co.uk/search?q=flexi ... NHLzZnM%3A
It is currently Sat Jan 11, 2025 9:57 pm
